Moderator
Posts: 2564 from 2003/2/24
64 and 128MB versions lack the Duallink-DVI port needed for that res at 60Hz. OSX can and will clock that down to 30Hz on a Singlelink-DVI MorphOS won't/can't.
So....
- make sure you have a genuine Apple 9600, flashed PC cards won't do
- check if your connected to the right port or are running at 30Hz in OSX (only 1 port on that card has Duallink)
