Which SSD for a iMac G5 2.1 20" iSight ?
    LuckyHazlenut
    Posts: 15 from 2021/4/6
    Hello everybody,
    I wanted to install an SSD in my iMac G5 2.1 iSight today ...
    Unfortunately the SSD was not recognized, but I know from videos that they are.
    Can you recommend one to me?
    Do you also use one yourself?
    Tested:
    Crucial MX500 (240GB)       - Not Working
    Intel SSD 320 (120GB) - Working
    SanDisk SSD Plus (240GB) - Working
    Intenso SSD (240GB) - Working
    best regards
    iMac G5 2.1 20" iSight (PowerMac 12.1)
    Registered MorphOS 3.15 since
    -- (11.04.2021 - 23:30) --
  • »16.04.21 - 22:21
    matt3
    Posts: 784 from 2004/2/10
    The Power Macs are picky with SSD's. I used a Sandisk Plus SSD, as they are recommended for the Mac. The OWC's seem to be over rated a bit, but some people are using the OWC 3's with no problem. Again this is in the Power Macs, but I would bet it would be the same in the Imac. Good luck!
  • »16.04.21 - 23:02
    LuckyHazlenut
    Thanks for the answer.
    Yes, I've already heard that the SanDisk SSD's probably work in the iMac G5.
    best regards
  • »16.04.21 - 23:11
    analogkid
    Posts: 719 from 2004/11/3
    I'm using a Intenso JAJS600m256c 256 GB SSD in a Powermac G5.
  • »17.04.21 - 03:08
    MoerBoer
    Posts: 239 from 2019/10/15
    Using a SanDisk here as well on my iMac 20" G5 iSight, works great.
    I can't recall the model number as it was an old one I had lying around.
  • »17.04.21 - 06:38
    Posts: 19 from 2019/12/31
    Intel SSD 320 working in my iSight without any problems
  • »18.04.21 - 11:24
    BatteMan
    Posts: 290 from 2003/2/24
    I want to change my HD in my iSight too but I have a silly question : Is iSight have a SATA connector ?
    If not, which adaptator do you use ?
    Thx !
    EDIT : Oups, got the answer. There is a SATA I port in iMac G5 iSight ! Sorry for disturbed you ;)
  • »18.04.21 - 14:22
    Korni
    Posts: 473 from 2006/2/23
    Kingston A400 SA400S37/480G works fine here with Powermac7,3
  • »05.07.21 - 10:11
