PowerMac alternates sata port every reboot
    matt3
    Posts: 784 from 2004/2/10
    Just got Morphos running on the PM. Every time I reboot the Mac I have to switch the SATA port.
    This is crazy anyone have any ideas?
  • »27.03.21 - 19:52
    Posts: 3311 from 2003/3/5
    Sounds like misconfigured OpenFirmware env variables to me.
  • »27.03.21 - 20:59
    matt3
    Should I just reset the firmware? Or should I just look into the variables?
    I did a bit of searching and didn't find a good resource for the firmware, do you recommend a source for it?
  • »27.03.21 - 21:02
    matt3
    Reset nvram and reset all and that seemed to fix the problem for a few reboots.
    Now it is back to the same routine.
    [ Edited by matt3 27.03.2021 - 18:02 ]
  • »27.03.21 - 21:39
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Hmm, I remember having a similar problem with an SSD seemingly not being fully compatible to old G5 SATA-1 controller. A Samsung SSD Pro/Evo (?), don't remember which exact model it was. On the MorphOS side swapping around seemed to work for some time, on Linux I got SATA bus errors and r/w errors after some time... After I switched to some Sandisk SSD Plus (series recommended here in the forum several times) this problem disappeared completely.
  • »28.03.21 - 21:19
    matt3
    Does Morphos support any modern 3rd party SATA controller supporting modern speeds?
    [ Edited by matt3 29.03.2021 - 19:03 ]
  • »29.03.21 - 21:00
    Zetec-s
    Posts: 198 from 2008/7/10
    Does Morphos support any 3rd party SATA controllers?
    Taken from https://www.morphos-team.net/hardware;
    SiI3x12 two-port cards
    SiI3x14 four-port cards
    SiI3132 PCI Express SATA controllers
    On-board SATA on X5000
    On-board SATA on PowerMac G5
  • »29.03.21 - 21:02
    matt3
    Thanks Zetec, so only the old stuff. Too bad no modern fast controllers.
    [ Edited by matt3 29.03.2021 - 19:06 ]
  • »29.03.21 - 21:05
    Zetec-s
    What SSD are you using? I believe I read it was a OWC, but which model?
    I've just fitted a OWC Mercury Electra 3G in my G5 PCIe and its working perfectly under MorphOS.
  • »29.03.21 - 21:10
    matt3
    I bought a OWC Mercury EXTREME Pro 6G.
  • »29.03.21 - 21:32
    Zetec-s
    I think that might be your issue as OWC seem to recommend using a 3G on a Power Mac G5.
  • »29.03.21 - 21:45
