Radeon HD 4770 in Quad G5 resolution not supported
    Hey, when I replace my Apple Mac G5 ATI Radeon X1900GT video card with a PC Radeon HD 4770 I get either a "resolution not supported" or a "signal over range!" message depending on what monitor I use.
    Any idea what could be happening? I'm used to OS' identifying the monitor's specs and setting the resolution to suit.
    So far I haven't had a lot of luck with PC display cards in my Mac. I've tried a FirePro 3D V3800, v4800, and a V4900. This last card doesn't appear to be supported, but the first two create a display, however the color is a blocky bright green and the text is mostly unreadable.
    So, is there a way for me to force MorphOS to start at a lower resolution or frequency?
    I'd ask Mark, but he's a busy guy and I don't want to bother him.
    [ Edited by Jim 30.01.2021 - 06:39 ]
  • »30.01.21 - 10:36
    Posts: 12558 from 2003/5/22
    In case there's some misidentifying, this may help:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=12874&forum=9
    Pressing and holding CTRL during boot will force MorphOS to 1024×768 (60Hz) resolution.
  • »30.01.21 - 12:51
