Posts: 2077 from 2003/6/4
I got two el cheapo mSATA IDE converters via ebay directly from China. Both fit well and work reliable and fast (Mac mini and Powerbook). Both are equipped with identical Kingston mSATA drives
From my experience the cheap devices are also worth a try. One of the devices came with a 2.5" case which was nice to mount. Put that into the Powerbook as that case provides a bit more security in regard of staying in place.
