Overclocking Radeon 9200 Pro
    Cego
    Posts: 733 from 2006/5/28
    I have a Radeon 9200 Pro lowprofile AGP card in my Peg2 and want to squeeze out more performance.
    According to GraphicsBoard utility the chip runs at 240Mhz and the ram at 165MHz.
    Is it possible to increase Ram clock software wise? Maybe via tooltype?
  • »17.10.20 - 13:47
    Crumb
    Posts: 732 from 2003/2/24
    You could fit a radeon8500 if you want to keep warp3d compatibility, or a radeon9800pro if you don't mind running wazp3d. Alternatively I guess you could overclock a little your card modifying the tooltypes of Radeon monitor but I doubt It worths the hassle for so little gain
  • »17.10.20 - 15:32
    Cego
    Do you know the tooltypes?
  • »17.10.20 - 16:37
