Posts: 2217 from 2003/2/24
MoerBoer wrote:
I cannot for the life of me figure how to set the device unit 0 to use another output.
I don't know where this setting is. If I click on settings/system/audio, I just select the earphones on the left.
Then you only set the Music Unit, but for Unit 0 you'll have to click the popup gadget at the end of the "Music Unit" text line, and then select a different unit to configure.
I added three new screenshots there to make it more clear:
https://library.morph.zone/Tips_and_Tricks#Redirecting_AHI_Music_UnitThis seems to be a bit confusing many times, but when you get it, it's pretty clear. And it's a nice option if you have many audio cards / speaker setups, and want to output different things on different setups... maybe if you're controlling a professional audio system at a theatre or sports stadium, for example :P Or just doing DJing and want to hear separate audio on your earphones than your speakers etc :)
RNORadio uses Unit 0 always and that can't be changed.
[ Edited by jPV 20.07.2020 - 21:26 ]
