PowerMac 7 Fan Control
    Posts: 1087 from 2003/3/24
    PowerMac7 Fan Control
    Added a mechanism for users to tune certain fan control parameters
    Use drive bay temperature sensor to control the backside fan
    Found this in the release notes of MorphOS 3.12 so where can i tune these parameters?
    G5 Thermal Management
    Basic sensor support for PMac11,2
    And what does that mean? Can i run MorphOS 3.12 now on the Quad G5 with 2.5 Ghz?
    [ Editiert durch ThePlayer 20.10.2019 - 21:45 ]
  • »20.10.19 - 17:26
    Posts: 2577 from 2003/2/24
    Didn't we talk about that stuff yesterday (or was it already today)???
    PCIe G5 work but aren't officially supported (just like my iMac), you just have to supply a supported Radeon (ATOMBios or a rare Apple one) and NIC ( look here).
    As for the fans, during the initial beta phase cyfm provided me some fan related shell tools for the iMac but I can't find them on the ISO. So no idea wether these where just forgotten or if I should have looked for something else.
  • »20.10.19 - 18:29
    I'm pretty sure we didn't talk about it.
  • »20.10.19 - 19:45
    bigfoot
    Posts: 510 from 2003/4/11
    Actually, there is now away to control certain parts of the fan control software on PowerMac7 machines. However, due to an oversight on my part, the tool to do so never made it to the ISO.
    I'll make sure it gets included in MorphOS 3.13, in the meanwhile you can download it here:
    https://bigfoot.morphos-team.net/test/PowerMac7FanControl
    It's a command line tool using the standard ReadArgs() interface, so if you run PowerMac7FanControl ?, you'll get a list of possible arguments that you can give it that are hopefully more or less self-explanatory.
  • »21.10.19 - 18:46
    peg4a
    Posts: 26 from 2003/4/15
    Hi !
    Does this work on imacg5 too ?
    I just registered my imac, everything is working, except the fan control, so the machine can goes up to 100 °c.
    I know it is not supported yet ;)
    Except that, it is a great machine for Morphos !
    I could do betatests if needed.
    Peg4A
    Powermac G5
    2,3 giga mono processor. HDD : 750 Go sata ATI 9800 XT 256 mo.
    Morphos 3.4 ;)
  • »22.10.19 - 15:19
    Hmmm, mine for sure doesn‘t go as high as 100 degrees......
  • »22.10.19 - 18:33
    Posts: 1390 from 2010/1/6
    Does FanControl set permanent changes? Or is it needed at every boot?
    btw: reduced G5-2.3GHz CPU-Temp from 76°C to 69°C without more noice.....very fine!
    EDit: Seems not to be permanent.
    [ Editiert durch Amigaharry2 24.10.2019 - 21:39 ]
  • »23.10.19 - 06:39
    peg4a
    Hi !
    Could you tell me the exact command you use for this ? I don't understand well how it works...
    Thanks ! :)
    Powermac G5
    Morphos 3.4 ;)
  • »29.10.19 - 06:12
    In my case I want max CPU-Temp of 70°C:
    > CPUFanControl CPUTemperatureTarget 70
    > CPUFanControl ? gives you all comands.
  • »29.10.19 - 06:16
    peg4a
    Thanks ! I will try on my ImacG5 ;)
    Powermac G5
    Morphos 3.4 ;)
  • »29.10.19 - 07:14
    Posts: 611 from 2003/4/11
    It won't work for iMac, that is why it is called PowerMac>7< Fan Control ....
  • »29.10.19 - 08:12
    peg4a
    Ok thanks for the info. I hoped it could work on Imac too because on open firmware it is named powermac...
    Anyone has the Imac version for tests ?
    Thanks !
    Peg4A
    Powermac G5
    Morphos 3.4 ;)
  • »29.10.19 - 08:48
    Posts: 12557 from 2003/5/22
    The key is in the number. Your iMac is PowerMac12.
  • »29.10.19 - 09:37
