Unable to install Morphos 3.12 on Pegasos 1
    Goodman
    Posts: 115 from 2006/8/2
    Hello,
    I actually use Morphos 3.6 on 1024x768 which is the maximum res. I could use in my previous monitor. Now that I have a 1280x1024 Scree and AmbientMui can see it but when I try to change it get back to 1024x768. I tried another monitor it could work in even Full HD (!) mode but it get back to 1024x768. My graphics card: Voodoo 3 3000 PCI.
    When I try to boot from Morphosboot CD doesn't work and it autoreset repeatedly. My Morphosboot CD can be read after booting on Morphos 3.6 and can boot fine on Mac Mini.
    I guess if I use my old 1024x768 monitor is going to work. Later I'm going to try.
    Then I will change also my Voodoo for a Radeon 9250 PCI.
    [ Edited by Goodman 22.01.2020 - 14:25 ]
  • »22.01.20 - 12:23
    Posts: 2209 from 2003/2/24
    There is a bug in bootpeg1.img in MorphOS 3.12, and that makes booting on Peg1 with certain firmware setups to fail. If you're affected by this bug, you'll have to wait for 3.13 or use 3.11.
  • »22.01.20 - 14:47
    Goodman
    Thank you I didn't know it. I had plugged my previous monitor and it didn't work indeed.
    Then I tried a new Ati Radeon 9250 PCI and it didn't work at all: black screen and no signal, while it can work on a PC Windows. I didn't expect it!
  • »22.01.20 - 19:29
