ECC-memory on peg2
    Posts: 10 from 2004/1/30
    I searched the forums but couldn't fins any cold hard facts. I know that the Marvell DiscoveryII chip has full support for ecc-memory, but how do I activate it? Right now my Peg2 is on it's way, but I haven't bought any memory for it yet. I would like to buy 512MB Corsair Reg. ECC, but if I cant use the ecc-functions I could just as well go with a regular memory. Can anyone here help me out?
  • »30.03.04 - 04:46
    gunne
    Posts: 441 from 2003/2/25
    Hi
    What do you mean by activate it ?
    Gunne
    Best wishes, Gunne
  • »30.03.04 - 10:48
    I'm not quite sure. On my previous pc's there have been an option in bios to "activate" the ecc-support. I suspect that I must enable it in OF so the marvell-chip knows how to properly use the memory.
  • »30.03.04 - 11:29
    gunne
    Hi
    Well, I cant answer when it comes to firmware and on this matter. However from the hardwareside (bridge-controller) there should be support as that whats the specification says.
    When it comes to sofware, I dont know of any software for MorphOS where you can control thoose things.
    As for Linux, Im also unsure, the only thing I have heard about is Netfinity. However I have never used such software myself.
    I believe better you ask in some linux forum if there is some software for these kind of things.
    ECC memory are mostly used in some servers, as what i know, as these memory counts and buffers, or what they do, and are said to be safer.
    Gunne
    Best wishes, Gunne
  • »30.03.04 - 12:00
    gunne
    Hi again
    Did search around little
    Found this page; LinuxECC
    Gunne
    Best wishes, Gunne
  • »30.03.04 - 13:17
    matt3
    Posts: 764 from 2004/2/10
    Hi Kamelryttarn,
    I'm currently using a Corsair 512 stick in my Peg II. It works perfect. I will have to check if it is the ECC or not.
    Just thought you'd like to know if it was compatible with MOS and PegII.
    Have a great day!
    Matt
  • »30.03.04 - 19:40
    Trilkk
    Posts: 1 from 2004/1/19
    I currently have a 1Gb REG ECC Kingston memory module installed, it works fine.
    Of course, due to the issues with firmware or whatever I must boot to linux with mem=256M.
    Dunno about ECC being on or not, it works, so I don't even have to.
  • »03.04.04 - 07:32
    Neko
    Posts: 301 from 2003/2/24
    Linux memory bug: Fixed! :)
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »06.04.04 - 18:46
    muckboy
    Posts: 47 from 2004/1/15
    I have 512MB ecc-registered ram on my Peg2 - it works like a dream.
    PegasosII/G4@1GHz | 512MB PC2100 ECC/REG | Radeon9200/128MB | Seagate Barracuda 160GB@7200RPM
  • »06.04.04 - 20:08
