Booting MorphOS 3.12 on Pegasos 1
    _coliN_
    Posts: 70 from 2003/4/30
    Hello!
    I want to boot the new MorphOS 3.12 - CD on my Pegasos 1 via a burned CD-RW.
    Usually I do it with the following command:
    boot /ide/cd@1,1 bootpeg1.img
    Then I can update the system with the Installer script.
    With 3.12 it doesnt boot, and stops after loading the boot image. Then the cd-rom ends running and nothing happens.
    Tried it with different devices. The same reaction, when I copy the boot iamge to the boot disk, and change the boot command....
    The boot image of 3.11 has a size about 2.3 MB. The boot image of 3.12 has only 1.5 MB.
    Is it the wrong image on the CD???
    Can someone help me?
    Thanks!
  • »10.10.19 - 13:31
    _coliN_ wrote:
    Hello!
    Thanks!
    Could it be because you're using a CDRW, instead of a CDROM? I know that I created plenty of CD drink coasters because I burned them the wrong way in the past, but you're probably smarter than I was, and wouldn't make that mistake.
    I don't know the exact size of the "boot.img" file, but I would think that checking the size of the whole MorphOS.iso image file would be more important. The check sum for the morphos.iso image is listed on the download page IIRC.
  • »10.10.19 - 13:50
    Posts: 2220 from 2003/2/24
    I haven't been able to boot my Peg1 with 3.12 either, so there is probably some bug in the bootpeg1.img. I know that some other(s) have succeeded, but I certainly haven't. I have tried in several ways, from CD and by copying image to HD etc. I guess we'll have to wait for 3.13, but confirms from other people would be welcome too.
  • »10.10.19 - 14:07
    Posts: 12557 from 2003/5/22
    >> of 3.12 has only 1.5 MB. Is it the wrong image on the CD???
    _coliN_ fears that the MorphOS team put a wrong or defect boot.img for the Pegasos 1 on the MorphOS 3.12 ISO image. This is something entirely different than just a borked download, and the ISO image wouldn't show a different MD5 check sum in this case.
  • »10.10.19 - 14:10
    _coliN_
    I dont suspect a wrong or defect image. Perhaps its a wrong naming and a confusion with the images?
    I will try the Cd-R method, and then ask the developer team directly in the next days....
  • »11.10.19 - 05:00
    bigfoot
    Posts: 510 from 2003/4/11
    The reason the Pegasos 1, Pegasos 2 and Efika boot images are smaller in MorphOS 3.12 is that they're using a more efficient compression method than previously. It's the right boot image :)
    There have indeed been some reports of failure to boot on Pegasos 1, but we haven't pinpointed the problem yet. As we have limited access to Pegasos 1 machines on the MorphOS team these days, we'll have to rely on user reports to try to figure out what's causing the boot failure.
    What this means is that the more information you can supply about your system, the easier it will be for us to figure out what the cause is. What motherboard revision (original/April/April 2), what firmware version, how much memory have you got installed, which add-on boards have you got installed, what happens when you try to boot, when does it fail/stop and anything else you can think of would be helpful for us to know. If you have the required hardware/setup to capture serial logs, then that would be really helpful too.
  • »11.10.19 - 05:02
    At least "wrong image" was your own wording.
    Yes, that possibility I took to be included in the meaning of your "wrong image" wording. Besides the Pegasos 1, there would have to be at least one other MorphOS platform to fail booting 3.12 then, however.
  • »11.10.19 - 07:25
