Mouse and keyboard clicks frozen on startup!
    Rats
    Posts: 33 from 2013/1/22
    Hello!
    So I have had morphos running very well. I am trying to connect morphos as a synergy client in wb startup. The machine was working fine then
    7uhwMM8
    picture (it wont even let me click the check box)
    A month later I come to my g5 boot it to start morphos and the mouse clicks wont register even using the keyboard as a mouse the clicks wont register. Anybody know a solution to this as I really dont want to have to reinstall.
    I have also tried using another keyboard and no mouse and no luck
    [ Edited by Rats 16.07.2019 - 15:28 ]
  • »16.07.19 - 12:24
    Posts: 1385 from 2010/1/6
    Do you have access to keyboard in OpenFirmware-console or in MacOS?
    If it does, then it's MOS related. In this case your posidon-prefs may be corrupt. So try to boot without startup-sequence (hope you can reach early startup-menue by pressing F1 or left mouse-button during booting).
    Now you in a shell and should have access to your keyboard and can rename posidon.prefs:
    cd prefs/env-archive/sys
    rename posidon-prefs as posidon-prefs.old
    Now reboot! New posidon-prefs will be generated during run-time.
    Hope that will help...
  • »16.07.19 - 13:53
    Posts: 3311 from 2003/3/5
    It does not look like Synergy was able to connect to the server, so a remote mouse/kb wouldn't work at least.
  • »17.07.19 - 04:21
    Seems I missunderstood posting: Thought there was no HID-response after booting MOS....
  • »17.07.19 - 13:41
