Posts: 1372 from 2010/1/6
Peg2 should boot from MorphOS-CD, if inserted during system-boot. If not, there may be done some changes in OF.
To get into OF you may disconnect all bootabel devices. OF will then boot into OF-console. There you can set autoboot to false:
sentenv auto-boot? false. Now reconnect all devices. OF will always stop now with booting into the console.
To boot now from
CD: boot cd boot.img This may not work, if NV-Vars are set to different parameter. Enter
set-defaults to restore default parameters.
Autoboot should then been set automaticaly to true again. If not:
sentenv auto-boot? true.
Reason for your keyboard-failure: Some USB-keyboards are not recogniced from OF. PS/2-keyboards does'nt have that problems.
[ Editiert durch Amigaharry2 02.02.2019 - 11:12 ]Peg2, 3xPowerMac G5, 2xPowerbookG4, 2x MacMiniG4, Efika (again), A3000T and life is never boring.....
