Posts: 1385 from 2010/1/6
As I wrote you can map keys on the left side to keys on the right side. I.g. you can map "|" on every key you see on the left side. Use "track incomming events" to find the key corresponding to keymap, then choose your whished sign (key) on the right side and click on it. Test it with "use".
Here you will find poseidon 4.4 with included doc-guide (in install-data-directory): http://eab.abime.net/attachment.php?attachmentid=43371&d=1424864909
[ Editiert durch Amigaharry2 24.10.2018 - 13:31 ]Peg2, 3xPowerMac G5, 2xPowerbookG4, 2x MacMiniG4, Efika (again), A3000T and life is never boring.....
