Wath are the best drive parameters for SSD drive
    Posts: 23 from 2018/4/20
    I use a disk on module ssd drive on Pegasos I .
    Its work fine on Morphos 3.9 and 3.10 .
    On Morphos 3.11 i have troubels , i copy the sys: to Ram: and the system freeze before all are copy .
    Only by set partition buffers >= 4096 the copy sys: to Ram: 100% ok .
    drive parameters .
    RDB
    SFS
    boksize : 512
    max transfer : 0x7fffffff
    mask : 0xfffffffe
    buffers : 4096
    Maby i must make better drive parameters for SSD drive on module .
  • »08.07.18 - 21:18
