Synergy
    zbysiuk
    Posts: 59 from 2006/8/4
    Last time I got Dell Vostro from my friend and installed Mint 18 - perfect. I have two computers in one place (of course, I use Morphos), so it would be good to use only one keyboard and mouse. I tried to use the advantages of Synergy and connect two systems in this way (Synergy 1.4 and 1.8 in the case of the Mint), but with no effect. Maybe someone has done it before, so I will be grateful for any help.
  • »19.06.18 - 16:04
    Posts: 3311 from 2003/3/5
    If you want to use MorphOS as a server, you should consider using an older client than 1.8. Let me know what your setup is exactly...
  • »06.07.18 - 10:46
