Memory leak on Powerbook 5.2 and 5.4
    Posts: 23 from 2018/4/20
    If I run Morphos 3.8 or 3.9 or 3.10 .
    on Powerbook 5.2 and 5.4 the memory is gone afther 7 days.
    I must reset every week , a mounth ago the leak was stopped maby a task are crach .
    how can I find the program makes the memoryleak . with the Powerbooks 5.6 works all fine .
    - Ather 1 day running , the mouse move not nice , i kan solve that with
    the taskpri temperatur.sensor battery.sensor and Powerbook_service set to 0 .
    normal with 3.9 are that 20 and 25 by Morphos 3.10 .
    - and the keybordblacklicht are dedect wrong .
    as no keyborblachlicht the OSD work with press F8 F9 F10
    there are keybordblackl.. the OSD work not with press F8 F9 F10
    [ Bewerkt door Olystany 28.04.2018 - 22:11 ]
  • »25.04.18 - 13:30
    Posts: 3336 from 2003/3/5
    Thank you for the report. We will be looking into this...
  • »25.04.18 - 13:43
    asrael22
    Posts: 453 from 2014/6/11
    Could be the same (or same cause) I had reported for the iBook.
  • »25.04.18 - 14:41
    Yes, that is likely the same issue.
  • »25.04.18 - 14:48
    Found and fixed one possible issue. If you can, please run Scout -> Tasks, find battery.sensor task and freeze it. Let me know if the issue disappeared completely or if the leak velocity simply changed.
  • »26.04.18 - 09:55
    I can,t let work Scout to freeze a task.
    I use freeze for mos 3.9 .
    hardware for test Powerbook A1095 5.4 .
    new installation Morphos 3.10 .
    memory leak 145 MB / 24 hour .
    with freeze battery.sensor after 5 hour i see no difference .. tommorow test complete
    I test on A1046 Powerbook 5.2 .
    Morphos 3.9
    freeze temperatur.sensor
    freeze sensor.library
    freeze Powerbook_service
    the memory leak are < 2 MB / 24 hour .
    I will test more and find the Leak .
  • »28.04.18 - 19:06
    test with Morphos 3.10 on A1095
    I freeze battery.sensor
    the leak go a little faster and is stop afther 16 hours .
    then the leak <2 mb / 24 hours .
    maby sometings are crash ?
    OK i do more tests ......
  • »29.04.18 - 12:20
    Does the same happen when you boot from CD?
  • »29.04.18 - 12:31
    Do you mean boot and not freeze a task ?
    Yes the memory leak are also by boot from CD .
    I have 3 A1046 and 4 A1095 and 5 A1106 .
    I have a key van A1046 and one for A1095 and two for A1106
    the A1106 is the best , I run now 77 days with memory usage 7.6 % used.
    I have test all boot from CD , and let run a day with memory gauge .
    I did that 4 mound ago , and the memory leak on 3.8 3.9 and on A1046 , A1095 the same .
  • »29.04.18 - 18:20
    Thanks for continuing to bug me about this problem. The issue has been found and fixed for 3.11. I've never seen this myself since this was exclusive to older PowerBooks - two bugs in the PowerBook service task resulted in it scanning the teperature sensor list every second and allocating a sensor notification per each sensor found on every scan. This also made the OS slow down with time like Olystany observed.
  • »30.04.18 - 00:09
    OK thanks , the problem with keyboard-black light , are that found .
    ma by are the detection off exist keyboard-black light wrong by powerbooks 5.2 and 5.4.
  • »30.04.18 - 06:59
    Unfortunately I only have PowerBook5,8 and 5,9 so I cannot check anything related to the kb backlight on ADB machines.
  • »30.04.18 - 09:24
