Posts: 1348 from 2004/2/8
Jeckel wrote:
I noticed something strange dealing with NEC USB 2.0 PCI cards on Pegasos 2.
I'm using a NEC based PCI card since ages without any trouble.
It is working fine aside the built-in VIA USB 1.1 (which I still need because of a device not working properly in USB 2.0).
Since I needed additional USB 2.0 ports, I added a 2nd NEC USB 2.0 PCI card (exactly the same as the 1st one).
I can see it with ShowConfig, but Poseidon still only see the 1st NEC card and the built-in USB, even if I manually add a device. Nothing.
Then I replaced the 2nd NEC card by another NEC Card (different but same chipset). And here, I have a different behavior. I can see both NEC cards in Poseidon, but the built-in USB 1.0 is gone! Of course, ShowConfig still shows all the boards.
Is there a trick or did I find a bug?
I've heard of such behaviour (with a NEC based PCI USB controller, but in a PowerMac G5. When plugged in it makes the inbuilt ports dissapear). From what I know it's been already reported as bug, but I'd give it a shot anyway.
