fat95 was already there. Some more info:
The Nex II device shows up correctly on the 'devices' tab in the USB Preferences, as a mass storage device. I've been doing quite a bit of playing around with the mass storage device class settings, all to no avail.
It can read the vendor as "Texas Instruments", the mass storage device settings show L:fat95 (and DosType 46415401, which is FAT/1), and it shows LUN 0 as 'Nex II Digital', to be mounted under dosname UMSD.
A UMSD: device also exists with the NexII plugged in, but it's "not a DOS disk". Unplugging it gives a "no disk present".
It is very irritating that the device vendor and product name are recognized, plug / unplug are detected, but it's not properly mounted for some reason.
wlamee
Wouter Lamee
mailto:wouter@wouterlamee.nl
http://www.wouterlamee.nl
