Does MorphOS 3.9 support PowerBook G4 15" PCMCIA port?
    Posts: 1 from 2017/8/17
    Ok any MorphOS 3.9 + Crysalis users here? I need help... so my MorphOS setup is on a PowerBook G4 15" & luckily has the same PCMCIA port on the side as the A600, A1200. I have one of those SD-PCMCIA adapters & a 4GB SD card in it. The SD card operates properly when mounted via a USB card reader so that's not a issue. & I've used this adapter card on Amiga OS 3 so not sure why it doesn't seem to work with MorphOS. I've installed all the files I thought I was supposed to but still nothing all I get now is a annoying dialogue every time I reboot. Am I missing something?
    CFO & CFO.info are in "System/Devs/DOSDrivers/"
    compactflash.device is in "System/Devs/"
    fat95 is in "System/L/"
  • »20.09.17 - 06:28
    Posts: 1354 from 2004/2/8
    From what I know there are no drivers for PCMCIA (or rather Cardbus, as PowerBook's slot is 32 bit) for other devices than network WLAN cards with Atheros 5k chipset in MorphOS.
  • »20.09.17 - 07:14
    Posts: 3311 from 2003/3/5
    Afaik only Cardbus devices would work in the slot and only if plugged in at system boot. Your reader is 16 bit, which is a requirement for it to work in an Amiga.
  • »20.09.17 - 10:44
    I vaguely remember some discussion about the slots in Amiga A600 & A1200 being different (limited), compared to standard Cardbus and/or PCMCIA slots on mainstream hardware. I also think that some Cardbus devices, including wireless NIC's had been used successfully in a few PowerBook's running MorphOS, so if you dig long enough, I think you will find some examples of what works, and what does not.
    Sorry, that is probably not of much help.
    Edit: this post was meant for the original poster, not jadacaps.
    [ Edited by amigadave 20.09.2017 - 09:16 ]
  • »20.09.17 - 14:16
    Can you specify which Cardbus devices excluding wireless NIC's had been used successfully with PowerBook running MorphOS?
    [ Edited by koszer 20.09.2017 - 19:05 ]
  • »20.09.17 - 15:05
    No, my memory for this stuff is worse than it is for most other things, which is pretty bad. If I don't have a personal use for something, I tend to forget details, unless they are remarkable in some way, surprise me, or shock me, then I might remember them. When support for PowerBooks was first released, IIRC, I was using, or trying to use, a wireless Cardbus device with the Atheros chipset, but then I found and purchased a couple of different Ethernet bridge type devices (Netgear WCN2001 was one of them I think), which were easier to setup and use, so I lost interest in Cardbus devices.
  • »20.09.17 - 17:09
    I don't think we've tested anything but the wireless cards.
  • »20.09.17 - 17:12
