Powerbook G4 17" vertical red lines
    walkero
    Posts: 104 from 2006/3/1
    Hello all. I got a Powerbook G4 17" where I installed MOS 3.9, which I already registered.
    This computer has a Radeon9700M with 64MB of RAM, and I use it at a resolution of 1440x900. Unfortunately, there are some kind of red lines visible, depending the background color. For example, when I use the Mettalix wallpaper, there is a wierd circle of red and green colors.
    you can see the problem at the following photo.
    This problem is not visible when I boot to MacOS.
    Do you believe that I must change something at my configuration? Is it a known problem of MOS? Is there a solution?
    Thank you all for your help.
  • »04.06.17 - 15:01
    Posts: 1353 from 2004/2/8
    I'd try your Powerbook with an external display, to make sure it's not the panel issue.
  • »04.06.17 - 16:21
    Posts: 2209 from 2003/2/24
    Hmm.. I think I've seen similar looking issue many years ago, and I think there was some solution and it wasn't about hw, but I can't remember anything more now. I'll try to dig my memory or any traces if I can find anything about it :)
  • »04.06.17 - 16:31
    Posts: 1376 from 2010/1/6
    Try an older Radeon-driver (eg. from MOS 3.7).
  • »04.06.17 - 16:36
    walkero
    Thank you all for your replies. I install Chrysalis package and until now it seems it is resolved, as I don't see it anymore.
    I can't say where the problem was, but I wonder about the screen setup. I just saw that on this system the resolution is 1440x900 24bit, and I can't increase the color bit to 32bits. Is it logical?
    If this issue appear again, I will inform you guys.
  • »04.06.17 - 17:24
    walkero
    double post... sorry
    [ Edited by walkero 04.06.2017 - 23:21 ]
  • »04.06.17 - 18:21
    24 bit is the normal max resolution (>16 mill colors) for MOS.
    32 bit (24+8) is additional alpha channel (afaik) ...
    btw: 64MB VRAM isn't very much - I think you would run out of VRAM useing higher resolutions/depths, when useing more screens at a time...
    [ Editiert durch Amigaharry2 04.06.2017 - 22:55 ]
  • »04.06.17 - 18:52
    walkero
    Hello again. Today I started the machine and seemed to work just fine. I run the GfxSpeed performance checker and since then the problem came back. It happens now even if I restart the computer.
    Any clue?
  • »05.06.17 - 08:36
    Posts: 3280 from 2003/3/5
    Sounds like an issue with the soldering of the graphics chip or micro cracks on the mobo - had the same problem with my old 17'' PB. Ended up replacing the mother board since attempts to fix this with a heat gun did not help.
  • »05.06.17 - 09:35
    walkero
    If it was this issue, would it do the same under MacOS X, or even do it all the time under morphos? What I saw also is that if I reduce the colour bits, the wrong color lines move to an other position and are mostly green.
  • »06.06.17 - 18:56
