Posts: 1086 from 2003/3/24
Hi, i try to install MOS 3,9 on a PowerMac G5 7,3.
The Mac has 4GB Ram and a Radeon 9600 256MB Ram Apple Edition. For Install i use only 2GB of Ram.
When i boot from the MOS CD and the language and keyboard screen loads. The screen starts to go black for a sec. and then it shows the screen again. This is repeating all the time till i press ok. Then MOS boots into Ambient. And when i press Install in the installer, nothing happens. Sometimes i can open the MOS Disc sometimes not, can't eject the CD in MOS. I Have to reboot.
I downloaded the 3.9 Iso twice checked the MD5 and burned the Iso with two different PCs. But it's allways the same Problem. Installing OSX i had no Problems and it runs fine. Any hints or ideas?
[ Editiert durch ThePlayer 10.04.2017 - 14:12 ]PowerMac G5 Quad 2.5 running UWQHD Resolution
