Is the microphone of the Powerbook supported in MorphOS?
    igracki
    Posts: 469 from 2003/2/24
    I quickly read the Powerbook manual (from the "conditioning the battery" thread) and saw that there is a microphone hidden under the left speaker!
    Is it supported in MorphOS?
  • »26.02.17 - 12:04
    zukow
    Posts: 654 from 2005/2/9
    yes, it is
    try ahirecord from aminet
  • »26.02.17 - 16:51
    igracki
    Cool, I tried AHIRecord v1.21, the OS3 version, and it works!
  • »26.02.17 - 18:48
    GMKai
    Posts: 259 from 2003/4/7
    good to know,
    after a quick test the file does not replay succesfully.
    What settings did you chose?
  • »28.02.17 - 06:54
    igracki
    I used Wav-24bit, did you pressed the CloseAHI button before you replayed the recorded sound?
  • »28.02.17 - 13:07
    GMKai
    Good point, that did the trick...
    now I record and replay...
  • »28.02.17 - 16:12
