MorphOS on an overclocked Powermac G4
    CountRaven
    Posts: 566 from 2007/12/10
    I tested with PC2700 DDR SDRAM @ 333Mhz the RAM type which officially supported by this machine.
    I was using PC3200 @ 400Mhz
    Same symptoms.
    So the last thing to check is a Radeon card and / or driver.
    Anyone with a spare Radeon card drop me a line :)
    I am thinking to test a driver from an even older ISO -in the past I have checked an older one but can not remember now-, any recommendations?
  • »28.10.16 - 16:22
    Yeah, they aren't that picky about memory.
    I've run PC2700 and PC3200 without a problem.
    I may have a spare 8500 after I buy redrumloa's G4 this Thursday (if the 9600 I have on hand works in it).
    Otherwise I think I have the flashed 9800 I was supposed to send you around here somewhere, but I don't recommend flashed cards anymore.
    The have issues.
  • »28.10.16 - 16:45
    CountRaven
    Thanks Jim. Check with the 8500 and come back to me. Other offers also welcome.
    Yes I would also avoid flashed cards.
  • »28.10.16 - 17:59
    CountRaven
    After vairous tests I have found the reason of this strange behavior -see my first post-.
    After I deactivated the enhanced display option on the screen settings the machine works normal.
    The G4 wears an ATI Radeon 9600 AGP. 256MB.
    Do not know if it is a bug or something...
  • »03.02.17 - 01:08
    Did you still want the Radeon 8500 I received from redrumloa?
    It works, but I replaced it with a 9600 I had on hand.
    I'm willing to ship it to you at my expense since I owe you a favor.
  • »03.02.17 - 10:03
    CountRaven
    Yes Jim! Will PM you about this! Thanks!
  • »03.02.17 - 11:24
    Cool, glad to help.
    That goes for anyone else outside the US as well.
    Oh, and a quick note, red's G4 is running superbly, but doesn't liked to be overclocked (so eventually I'll be swapping in a 1.33GHz Xserve cpu board...as soon as I relocate it).
    If you get the right Radeon 9600, they make a good match for the G4, and they are cheap.
  • »03.02.17 - 15:15
    Jim wrote:
    Cool, glad to help.
    What problems are you seeing with your MDD overclocked, and is it the single G4 CPU module, or a dual G4 CPU module that you have overclocked? What overclock speed are/were you using?
  • »03.02.17 - 17:03
