Posts: 2217 from 2003/2/24
I guess bigger resolution could be slower in certain cases in theory, but you probably wouldn't notice much in real use. In any case people have been using even bigger resolutions than that 17" has with slower graphics cards too.
128MB graphics memory will be more than enough for both resolutions, no worries about that.
In my opinion the decision is just if you like the machine being more portable (15") or would you prefer bigger resolution to work with (17"). 17" is pretty large physically and may be a bit clumsy in that way if you need to carry it with you often, but it's also a pretty sweet looking screen for a laptop :)
I myself have 17" A1139 and then 12" and 14" IBooks, and if I'd have to choose just one, I probably would look for a 15" A1138 myself. Although I haven't used one, but it sounds like a fine compromise between resolution and portability.
