Radeon 1950 for the Sam460
    Mozzerfan
    Posts: 105 from 2016/10/5
    Hi Bigfoot,
    I discovered 2 more problems with the X1550.
    I can't use a 1680x1050 screenmode. The screen is a total mess. I took a picture.
    Also cpu usage monitor has similiar problems like mplayer. I made a video.
    I've sent a PM with the links.
  • »10.10.16 - 07:33
    bigfoot
    Posts: 510 from 2003/4/11
    Thanks for the descriptions and video/image links. From this info it's clear that the overlay issue and the Task Manager issue are the same thing, and I know what the problem is. When it comes to the resolution related issues I'm also fairly sure I know what's causing them.
    I'll try to get some time to fix these issues in the near future and I'll get back to you when I have something to test.
  • »12.10.16 - 17:28
    Mozzerfan
    Ok, many thanks Bigfoot for looking into this.
    I hope you can fix the problem with enhanced display too.
  • »13.10.16 - 04:20
    Lord76
    Posts: 81 from 2014/8/31
    wrong tread
    [ Editiert durch Lord76 23.01.2017 - 10:09 ]
    Powerbook G4 A1138/39
    Powermac G5 2.7ghz / G5 11.2 2.3ghz
    Amiga1200 V1200/Pistorm
  • »23.01.17 - 08:08
