FOR DEMO-CODERS.....
    Sphinx_Ra
    Posts: 276 from 2003/3/15
    Hi!
    Just want to show ppl this file:
    http://jpv.wmhost.com/releases/DSTARTUP.LHA
    It's for ppl who code demo's to work with
    diffrent OS's, as i sick am of not playing
    my OLD PPC Demo's... :-(
    Maybe this file is already notice but just a note :-)
  • »20.03.04 - 22:15
    hooligan
    Posts: 1948 from 2003/2/23
    I posted it to Demoscene-mailinglist. Thanks.
  • »21.03.04 - 12:43
    Chain-Q
    Posts: 350 from 2003/10/12
    I don't think using this stuff is such a good idea. For eg. it uses Player6.1A, which is Paula-only MOD player and doesn't supports AHI, which would prevent running demos on Pegasos. Also it contains heavy amount of 68k asm code, which maybe also not a very good idea for PPC demos... :-)
    The main problem with most PPC demos, that they use hacky code. I've even have widely used PPC-demo src examples, which calls themselves "system friendly", and yes the use CGFX and stuff, but still don't run on Pegasos, because using direct Amiga chipset access to check mouse and such lame stuff... :-(
    [.Hosting AmigaSpirit.hu.]
  • »21.03.04 - 23:16
    Estrayk
    Posts: 142 from 2003/12/30
    By the way, any MOD_replayer source for AHI available to the public?
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »22.03.04 - 00:09
    Infinity
    Posts: 29 from 2003/5/7
    I'm searching for a digibooster replayer.library
    Cu
    Andreas
  • »22.03.04 - 08:21
  • elf
    elf
    Posts: 32 from 2003/5/24
    I wrote one few years ago. Its on aminet:
    ftp://de.aminet.net/pub/aminet/util/libs/dbplayer.lha
  • »22.03.04 - 10:13
    Infinity
    Is the digibooter.lib working with MorphOS?
    Currently we are using your library for an Amiga PPC Demo. It would be very nice if its workink on MorphOS too!
    Cu
    Andreas
  • »22.03.04 - 10:37
  • elf
    elf
    I dont know, but I see no reason why it shouldn't work on morphos. there is no hardware banging IIRC, and it uses AHI for playback.
  • »22.03.04 - 11:00
    hooligan
    A replayer sourcecode for Digibooster should be made available as soon as possible. And I wouldn't mind trying out DB demo soon ;-)
  • »22.03.04 - 14:37
