Powerbook trackpad weirdness
  • esc
    esc
    Posts: 160 from 2013/5/27
    Hey guys,
    Using a powerbook - 1.67ghz model - the trackpad behaves strangely. Has anyone else noticed this or figured out a workaround?
    Basically, the cursor tracks horizontally quite fast but vertically quite slow.
    Additionally, the cursor will occasionally jump across the screen, typically far to the left. Can anyone help me troubleshoot?
    Thanks!
  • »19.12.16 - 21:41
    Posts: 3311 from 2003/3/5
    Try lowering the sensitivity in Touchpad settings.
  • »19.12.16 - 23:29
    NewSense
    Posts: 1601 from 2012/11/9
    Is it a 15" or a 17" Powerbook? Model?
    I've had some issues as you've described using my A1138 (15") with MorphOS, but I will also try lowering the sensitivity in the Touchpad Settings, as suggested by jacadcaps
  • »20.12.16 - 01:34
  • esc
    esc
    It's a 17". Lowering sensitivity helped a bit, but I think the geometry still feels a bit weird insofar as how quickly it traverses horizontally vs vertically.
    Thanks guys!
  • »20.12.16 - 15:18
    NewSense
    I've not adjusted my A1138 Powerbook Trackpad settings as yet, but I'll report back here as to any improvements once I've changed them. 8-D
    Saying that the Airport Extreme and other Wireless solutions seem to not 'make the most' of any signal around with MorphOS, compared to Mac OSX - maybe it's Apple's Interference Robustness that helps I can't say/know. However, MorphOS still seems to need some improvement in that area. and whether it's a bit more work that's needed to get the Trackpad driver to be 'honed to perfection' I don't know, but I think a little bit of tweaking might be beneficial, and probably might be in the works - though I don't know as we're still waiting for v3.10, and it has been quite a long wait by MorphOS standards. ;-).
  • »20.12.16 - 21:12
    deka
    Posts: 136 from 2013/2/12
    "though I don't know as we're still waiting for v3.10, and it has been quite a long wait by MorphOS standards"
    It could be a nice Christmas present, but a wonder if this will be corrected. I mean, it seems to me that the strange behaviour of the trackpad isn't considered as a bug.
  • »21.12.16 - 05:55
