Serialpl2303.device
    pan1k
    Posts: 147 from 2009/1/20
    I bought a usb -> serial device based on the PL2303 chipset. Morphos seems to recognize it, I downloaded term and have a network switch with a null modem cable for the console. I selected the correct driver in Term but I get no output from the switch. If I use the same cable on my MacBook Pro I get output from the switch. I have selected the parameters in Term to match the switch needs but nothing.
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »12.11.16 - 13:57
    zukow
    Posts: 661 from 2005/2/9
    could you post:
    vendor id, product id and photo of Your converter?
  • »12.11.16 - 19:16
    Jeckel
    Posts: 133 from 2007/3/11
    Are you using the latest version of MorphOS?
    I had issues with pl2303 devices under older versions of MorphOS, but it was fixed later.
  • »13.11.16 - 07:26
    asrael22
    Posts: 453 from 2014/6/11
    Yeah, I had issues as well. But it should be fixed in the current version of MorphOS.
    Manfred
  • »14.11.16 - 17:06
