Triple booting on Sam460ex
    Intuition
    Posts: 1116 from 2013/5/24
    > many kludges and work arounds in the codebase due to still supporting the broken Eyetech
    > hardware perhaps?
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8931&start=196 ;-)
    You've lost me there Andreas. :)
  • »16.10.15 - 12:40
    Posts: 12557 from 2003/5/22
    >>> hardware perhaps?
    I thought you were alluding to the broken cache coherency of the Articia S northbridge the OS4 developers had to work around. As you can see from my link, MorphOS 3.8 had to be enriched with similar "kludges" in order to support the non-coherent caches of the PPC460EX.
  • »16.10.15 - 13:01
    Intuition
    >>> hardware perhaps?
    Oh right I see. Didn't see any references to it in your link so i got confused. Easily done these days tbh lol
    [ Edited by Intuition 16.10.2015 - 15:20 ]
  • »16.10.15 - 13:19
    That's because you probably use "newest first" sort order. I was referring to comment #197.
  • »16.10.15 - 13:40
    Intuition
    Yup, seen it now.
    So that rules out the second part of my original statement and just leaves the first. Less skilled coders. ;-)
    [ Edited by Intuition 16.10.2015 - 16:55 ]
  • »16.10.15 - 14:55
    Doffo
    Posts: 508 from 2010/10/14
    Tried the benchmark of that Promethus trailer, and the 1.25ghz OC to 1.5GHZ single core MDD Mac averaged a 88.888 seconds.
    Gave the DP 2.7GHz G5 a shot, and achieved:
    BENCHMARKs: VC: 38.150s VO: 0.019s A: 0.000s Sys: 0.848s = 39.017s
    BENCHMARK%: VC: 97.7785% VO: 0.0491% A: 0.0000% Sys: 2.1724% = 100.0000%
    Not too bad. :) May give that other video file a try later on.
    YUUUP!
  • »16.10.15 - 16:45
    Spectre660
    Posts: 276 from 2015/6/30
    [ Edited by Spectre660 12.09.2016 - 23:21 ]
  • »09.09.16 - 10:32
    Spectre660
  • »09.09.16 - 10:35
