PowerMac G5
    beworld
    Posts: 669 from 2010/2/10
    hi all,
    My PowerMac G5 died when I added a USB PCI card ( dead motherboard )
    So I change motherboard but MorphOS is no longer registered . Is there a procedure for this case ?
    Thanks you
    IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »04.04.16 - 16:02
    Posts: 2555 from 2003/2/24
    Run RegTool and add a comment bout the dead G5. The team will get back to you and eventually send you a keyfile for the new G5.
  • »04.04.16 - 16:42
    beworld
    ok thanks you !
    My MOS ports
  • »04.04.16 - 16:51
    beworld
    done, i send registration and confim my email.
    My MOS ports
  • »04.04.16 - 17:50
