Powerbook G4 won't boot into MOS
    matt3
    Posts: 785 from 2004/2/10
    My Powerbook G4 boots past the question mark and finds the OS and immediately freezes on a gray screen with the front LED going solid on.
    I tried booting from the MOS CD and it has the same issue.
    Tried resetting the power management and NVRam. No change.
    Any ideas?
  • »04.03.16 - 12:58
    DanicaTalos
    Posts: 471 from 2010/10/15
    Try a Linux Live-CD...
    iBook G4 - 14" -1,42 GHz - 32 MB VRAM - 1,5 GB RAM - 60 GB mSata - MorphOS 3.20
    Mac Mini G4 - 1,42 GHz (OC 1,50 GHz) - 32 MB VRAM - 1,0 GB RAM - 120. GB mSATA - MorphOS 3.20
  • »04.03.16 - 15:59
    Cego
    Posts: 739 from 2006/5/27
    which PowerBook model do you have? Could you name some specific info?
  • »04.03.16 - 18:23
    matt3
    Sure it's an A1139 - 17in 1.67 high res. The last of the Powerbook line.
  • »04.03.16 - 18:35
    Yasu
    Posts: 1724 from 2012/3/22
    This is the same model I have and it works fine so we can rule out that this is a MorphOS inherited problem at least. It sounds like a hardware problem. The hard disk is my guess.
    My MorphOS blog
  • »05.03.16 - 09:10
    Posts: 2220 from 2003/2/24
    You have MorphOS installed on it and it has worked earlier?
  • »05.03.16 - 09:18
    matt3
    Yes I did. It worked well but it starting acting up and now it won't even turn on.
    Sadly it's broken. I hope I can transfer the license one I pickup another Powerbook...
  • »06.03.16 - 17:40
    Elowan
    Posts: 214 from 2011/4/18
    Hmmm, I got some "freezes wit grey screen" issue a few days ago - it was a currupted filesystem.
    Maybe try resetting NVRAM or external hdd
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »07.03.16 - 10:56
    Intuition
    Posts: 1116 from 2013/5/24
    Have you got RAM sticks in both slots?
    The second RAM slot is notorious for being broken by design.
    Try with RAM in only the first slot.
  • »07.03.16 - 11:55
    matt3
    Looks like the hardware is totally shot. Nothing gets power.
    It ran MOS for many years without issues and I did check the ram slots thanks!
    Does anyone know if there is a process to move the license to another computer or do I have to purchase another license?
    I just ordered another Powerbook with the same specs as the old. I hope to move the hard disk over and be up and running.
  • »09.03.16 - 10:53
    And you did reset the PMU with correct steps for your model? https://support.apple.com/en-us/HT1431
    You don't happen to have another battery to try? Or have you tried without any battery?
    Contact MorphOS Team for licence transfer.
  • »09.03.16 - 11:38
