Posts: 568 from 2003/2/24
Hello MorphDelf,
it can be tricky to use the "early startup sequence"
I'm at my work now, so I don't know exactly the right words.
In the BIOS, type help. This will show you which commands you can use.
I believe "show-devs" gives you all the attached peripherals on your Peg. Check if you see something like: "/pci8000.../ide...../cd.."
Now play with the command "ls" and what you found with the "show-devs"-command.
Important, if your CD-ROM isn't recognised, you won't see this peripheral show up with "show-devs".
Oh, search the forum, somewhere I did mention this part
Good luck,
Spidey
