PowerMac G5 Question - looking for compatible models
    Elowan
    Posts: 214 from 2011/4/18
    hello,
    the PowerMac 7,2 and 7,3 are compatible, but from what I´ver read, PCI (x) models are not?
    So this will not be compatible: PowerMac 1047 (just to clarify)
    kind regards
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »02.03.16 - 08:54
    Posts: 2564 from 2003/2/24
    PCI-X is supported, PCIe not.
    The one in your link is the best supportet model if you want to stay away from liquid cooled ones , just make sure it really has the Radeon not a BTO or aftermarket NVidia.
  • »02.03.16 - 09:58
    Elowan
    Aaahh, nice!
    Thing is, there is no iMac G5 support (which I would buy a license for), so I am looking for a G5 PowerMac to test it and decide, if I should reg to my MacMini (unlikely, because it´s mainly on owncloud server), my "new" iBook 1.33 which is on the way to me or the G5 killer-machine ;=)
    Or maybe I just buy two licenses...
  • »02.03.16 - 11:39
    Posts: 2217 from 2003/2/24
    This list might be helpful: http://library.morph.zone/Supported_Computers
  • »02.03.16 - 12:05
    Elowan
    Thank you - this list is much more detailed then the one I saw..
  • »02.03.16 - 13:05
    Elowan
    Cool, looks like I got a dual G5 2.3Ghz in mint condition for a real bargain :)
  • »02.03.16 - 15:47
