EnGenuis Wifi adapter
    Punkyclown
    Posts: 37 from 2015/2/15
    I running Morphos 3.9 on a Mac Mini with no built in wifi. Is it possible, or is there a wifi driver I
    could use to get this to run. Also I have read the docs but I can't seem to find where I would enable
    wifi. Can someone point me to that, would it just show up under network preferences?
    Much appreciated, Brad Hansen
  • »23.02.16 - 15:26
    defender
    Posts: 249 from 2011/4/24
    There is always a way to have wifi if you have an RJ45 Network port. You can use for example this
    Access point as wifi adapter : tp-link n150 tl-wr702n
    You can use nearly every old wlan Fritzbox to connect as wifi adapter. They are cheap to get from ebay
    and can maybe solve your distance problem better then internal solutions.
  • »23.02.16 - 17:12
    Punkyclown
    Thanks for the information, but what exactly is a Fritzbox and how would I search it on eBay?
    Brad Hansen
  • »24.02.16 - 15:24
    Posts: 12557 from 2003/5/22
    http://en.wikipedia.org/wiki/Fritz!Box
    With the terms "fritzbox" or "fritz!box" I presume ;-)
  • »24.02.16 - 18:00
    Unless you are on my side of the Atlantic.
    Because here all the eBay sellers for these are European (mostly German).
    I always thought that was a neat group of devices (basically rather nicely enhanced routers).
    The German's always build such nice hardware.
  • »24.02.16 - 21:25
