Posts: 2217 from 2003/2/24
Yes, it should boot with AC power in any situation. I think I had similar issue while ago. My Powerbook suddenly stopped powering up and I thought it broke down. But then googled around and found a way to reset something which helped and it started to work just fine again. Too bad I didn't do any notes for the future references and seems I only have vague memories about it now :)
But my guess is that I did reset the PMU (Power Management Unit) like this:
https://support.apple.com/en-us/HT1431
It was really easy for my PB5,9...
If that doesn't help, I guess reseting nvram/pram or something like that could help. In any case I'd bet that it isn't hardware failure even if I could look like that. Luckily we have these common machines and web is full of information about them :) Imagine these problems with custom boards which have sold few hundreds max ;)
With an old machine you probably should also do battery calibration at some point. I think it went like this: charge the battery full, unplug the PSU, use the machine until it shuts down, connect the PSU and let it charge the battery full while machine is turned off.
