wifi antenna Pbook 5,4
    amiga4001
    Posts: 451 from 2006/11/16
    I am using a Pbook 5,4 and the internal wifi off the Pbook.
    This workes ok for a minute or so then I loose connection.
    Only shutdown and restarting makes the connection come back to live.
    I now placed a pcmcia wifi card and voila no more problems.
    Is the wifi antenna off these Pbook on it's way out?
    It does show full strength off the signal all the time even when connection is gone.
  • »26.01.16 - 04:58
    imax
    Posts: 41 from 2004/9/20
    This problem appears in both system OSX & MOS ?
  • »26.01.16 - 17:11
    amiga4001
    Sorry no OSX only MOS.
  • »26.01.16 - 19:29
    imax
    Any UNIX system ?
    First you have to figure out an error in the hardware or software
    I myself often see : Failure reciving data peer
    [ Edited by imax 03.02.2016 - 23:39 ]
  • »03.02.16 - 18:36
