No LAN or WiFi connection on iBook G4
    Elowan
    Posts: 214 from 2011/4/18
    Hi there,
    I booted 3.9 from CD and tried to connect to internet with OWB, but can not get a connection. Is it a problem with iBook hardware or is it, because I have no hard disk install?
    Cheers!
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »19.01.16 - 18:05
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Did you read http://library.morph.zone/Configuring_Network ?
  • »19.01.16 - 18:30
    Elowan
    Thanks, I did not read it before!
  • »20.01.16 - 05:31
