PB G4 Alu Fans don't spin fast anymore
    defender
    Posts: 249 from 2011/4/24
    I'm nearly sure that this had been on topic before - but I can't find it.
    The fans do work - that means I can browse the Net as long as there
    is no advertising.
    Playing games for max 5 mins. and my machine is at 60 degrees celsius.
    help wanted ! thank you !
  • »02.12.15 - 18:12
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    is no advertising.
    Clean the cooler and the Fan. Then put thermal paste between the cpu and the cooler.
  • »02.12.15 - 18:50
    is no advertising.
    Some of the best advice I ever got from one of the MorphOS Dev. Team members, was to purchase replacement parts for my G4 PowerBook while they are still available and somewhat easy to find. Specially the parts most prone to fail, like the cooling fans, the Power Management board (can't remember exactly what its real name is), and the SuperDrive DVD writer.
    Replacing the cooling fan assembly is sort of a PITA, but can be done with patience and the right tools (torx & phillips screw drivers).
    If you can find new replacement fan assembly for your PowerBook, I would suggest just replacing it, instead of only cleaning, as it is many years old by now and because the trouble to take it all apart, it makes more sense to replace, instead of only cleaning. That is if you can find replacement parts that are new, or refurbished with new fans.
  • »02.12.15 - 18:58
    Posts: 3280 from 2003/3/5
    60C is pretty normal for a PowerBook.
  • »03.12.15 - 08:52
    drphil
    Posts: 36 from 2015/11/28
    @defender
    I've got a PowerBook G4 which I have stripped down for parts
    Apart from the display (which is bung) Let me know what parts you might need and I can send it to you if you like :-)
    1.6Ghz PowerMac G5, 2GB RAM, 80GB HDD, MorphOS 3.9.
    Why make life difficult when with a bit of effort you can make it impossible
  • »03.12.15 - 20:54
    defender
    OK but I can't hear the fans spinning higher, that is why I shut the PB
    down when it gets hot.
    Is there a way to test the fans ? maybe a test program even if its on linux or
    OSX. Before tearing apart my PB i would like to be sure that its a hardware
    failure.
  • »04.12.15 - 19:29
    defender
    drphil schrieb:
    @defender
    Thanks a lot, but I think the shipping costs are unbelievable to germany.
  • »04.12.15 - 19:37
    drphil
    Would you like me to find out the cost of shipping for you? Which exact part would you like?
    Cheers
    Phil
  • »04.12.15 - 20:18
    drphil
    Shipping to Germany from N.Z should cost 15-30 euros max.
    I wont charge you for the parts ;-)
    Let me know if you're interested
    Cheers
    Phil
  • »07.12.15 - 03:22
