Radeon 9800 @ PowerMac G4 MDD @ MorphOS
    CountRaven
    Posts: 566 from 2007/12/10
    http://1drv.ms/1PtphOw
    Does anyone knows why this is happening? The card is a Radeon 9800 Mac Edition.
  • »14.11.15 - 21:17
    Posts: 2564 from 2003/2/24
    What is actually happening ?
    And no a shaky upsidedown cellphone-video does not say more than 1000 words ;)
  • »15.11.15 - 06:07
    CountRaven
    My 1200 with AGA is faster...
    This is a MorphOS 3.9 install look how slow the system behavior is on graphics...
    And when I open a video on mplayer it just shows some random colors.
    It is a driver issue. Using an older Radeon driver brought everything to normal.
    I replaced the 52.23 version from 17-5-2015 with 52.21 from 22-6-2014 and everything runs normal now.
    [ Edited by CountRaven 15.11.2015 - 09:41 ]
  • »15.11.15 - 07:35
    bigfoot
    Posts: 510 from 2003/4/11
    The video link doesn't work for me.
    Can you take a screenshot of the utility called 'GraphicsBoards' as well as the output of 'showconfig' when run in a shell?
  • »15.11.15 - 11:18
    @Countraven
    "slow" was hard to guess from that video, as my G5 allready struggled playing it ......
  • »15.11.15 - 12:37
    pampers
    Posts: 1068 from 2009/2/26
    For me his hw acceleration gets turned off.
    MorphOS 3.x
  • »15.11.15 - 12:42
    CountRaven
    Sure. Here it is: http://i254.photobucket.com/albums/hh109/CountRaven80/Grab_zpsysgpw74k.png
    If you need same screenshot with the latest drvier installed let me know.
    Thanks.
    How I would check this?
    [ Edited by CountRaven 15.11.2015 - 18:43 ]
  • »15.11.15 - 16:42
    pampers
    Check ur debug log
    MorphOS 3.x
  • »15.11.15 - 17:36
    CountRaven
    OK
    Is there a setting that I should change to enable / disable it?
  • »15.11.15 - 17:51
    pampers
    Right click on the top right corner on screenbar modules, just turn on debug and then you will get debug icon in screenbar. After this slowness happens just click on the bug icon and see if there is any log there.
    MorphOS 3.x
  • »17.11.15 - 04:35
