Posts: 2217 from 2003/2/24
Yeah, booting with Alt key pressed to get into boot menu is the first thing to try to get CD booted, and if neither C or Alt won't work, try connecting keyboard directly to the mini and don't use any hubs.
About the boot image problem... one guess which it might be. If you have modified/copied the bootinfo.txt file in the Boot: partition (HFS), the machine won't recognize it until you run "HFSSetMacBoot Boot:bootinfo.txt" command in MorphOS's shell. You can do that by booting the MorphOS installation CD and no OSX required when fixing that. Usually if you want to update MorphOS boot files manually, it's enough just to copy the correct boot.img file to the Boot: partition. No need to touch the other files. There are few different boot.img files for different architectures and for Mac mini the correct one would be in the mac_ppc32 directory on the MorphOS CD.
