Question about PowerBook G4 15" M9969LL/A
    Posts: 2 from 2015/7/6
    hi
    i am planing to buy a PowerBook G4 15" M9969LL/A with Radeon 9700 128MB Graphic Card my question is it supporte to 3D and W3D Drivers ?
  • »05.09.15 - 22:57
    Posts: 2577 from 2003/2/24
    No Warp3D for anything above Radeon9250, but newer games useing TinyGL will work.
  • »06.09.15 - 02:12
    Thank you so much
  • »06.09.15 - 18:12
    Posts: 2094 from 2003/6/4
    amjackal schrieb:
    Thank you so much
    There's Wazp3D which provides some W3D compability by a soft renderer. Haven't tried it much, but only with WO2097 and there it works half okay in windowed mode at least.
  • »06.09.15 - 18:28
    Posts: 12557 from 2003/5/22
    > Wazp3D [...] provides some W3D compability by a soft renderer.
    It has got hardware rendering through TinyGL a while ago.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=9544&start=35
  • »06.09.15 - 23:33
