Morphos Support für envy24ht
    Spectre660
    Posts: 276 from 2015/6/30
    Depending on if a pci card would be seen behind a PEX 8112 PCI to PCIE bridge on a PCIEx1 to PCI adapter. If I get some time I will try it .
    eliot wrote:
    So in the end, there no way to use MorphOs with Sam460ex with Sata, Sound und Gfx???
    Which should be a good reason to wait for Xx000.
  • »30.06.15 - 11:37
    Spectre660
    And some Sam460's have envy24ht pciex1 cards so this is a a good platform to update the driver on.
    Jeckel wrote:
    The topic was about "Morphos Support für envy24ht" :p
    [ Edited by Spectre660 30.06.2015 - 09:45 ]
  • »30.06.15 - 11:39
    Posts: 12557 from 2003/5/22
    There are several ways to do this on the Sam460ex. On the Sam460cr on the other hand...
  • »30.06.15 - 11:46
    metatron
    Posts: 72 from 2011/11/18
    IIRC the sam460ex is fully supported. Currently you cant buy the sam460ex new but only the sam460cr. The sam460cr is a stripped down sam460ex:
    without onboard SATA, without onboard soundcard, without onboard graphics card.
  • »30.06.15 - 11:51
    https://acube-systemsbiz.serversicuro.it/shop/en/sam-motherboards/10-sam460ex.html
  • »30.06.15 - 12:52
    Posts: 1095 from 2004/9/23
    The Sam460ex is fully supported by MorphOS. This includes onboard sound, onboard SATA and onboard graphics.
    When using the 460cr version you need to pick supported hardware from the hardware compatiblity list as the onboard hardware got removed.
  • »30.06.15 - 12:54
    metatron
    What hardware would you recommend for:
    Graphics?
    Sound?
    Harddisk controller?
    P.S. can you tell me if PCIe->PCI bridges are supported in MorphOS?
    [ Editiert durch metatron 30.06.2015 - 15:24 ]
  • »30.06.15 - 13:22
    Posts: 655 from 2004/4/15
    Ah, sorry guys:
    I meant the Sam460 cr, not the "ex".
    So booting from sd with sata connected to pcie is possible?
  • »01.07.15 - 02:20
    >> The pciE 1x support is indeed a bit limited currently, we will look into
    >> that for a future update.
    Also the PCIe x1?
  • »01.07.15 - 04:31
    I wonder if ACube will reconsider production of the SAM460ex, now that MorphOS supports it fully? I am not interested in buying such a system, but there might be enough MorphOS users who want newly manufactured systems to make a small production run possible.
    Personally, I don't see the advantage of getting new hardware appealing enough, when compared to the performance and price of used Mac G4 & G5 hardware that is already supported, but I know there are some who prefer new equipment.
  • »01.07.15 - 07:13
    KimmoK
    Posts: 102 from 2003/5/19
    amigadave wrote:
    I wonder if ACube will reconsider production of the SAM460ex, now that MorphOS supports it fully?...
    I vote for as cheap production as possible, eg SAM460cr+SATA.
    btw. does MorphOS support DMA on the 460ex SATA port ?
    (This http://www.morphos-team.net/hardware does not show SATA support at all.)
    So, IMO, SAM460ex reproduction because of SM502 audio does not make sense.
    [ Edited by KimmoK 01.07.2015 - 13:29 ]
    :-x  :-P  8-)
  • »01.07.15 - 09:24
    What we need is an update to the Envy24 driver.
    Getting working correctly with PCI cards, then update it to work with PCIe cards.
    Problem solved.
    Why doesn't someone just plead with the author for the source code, clean it up, and incorporate it into the MorphOS distro?
  • »02.07.15 - 13:53
    boot_wb
    Posts: 874 from 2007/4/9
    Problem solved.
    http://aminet.net/package/driver/audio/Envy24HT
    No pleading involved, Davy offered them (with the noted disclaimer that this was all he could do).
    Nice guy.
    I guess our devs have been short of spare weekends. ;-)
    [ Edited by boot_wb 02.07.2015 - 18:16 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »02.07.15 - 16:12
    Dave actually offered to help.
    Damn, that IS really nice of him considering the poor sales that his Amiga port of Audio Evolution generated.
    Very cool.
    Wish there was a way we could properly thank him.
  • »02.07.15 - 19:23
    I think Amiga is the original platform Audio Evolution was written for.
  • »03.07.15 - 07:45
    And he moved on.
    Edit - Wow, I just looked over the source for that driver. Intense, no wonder no one has taken that one on. Looks like its time to re-install the SB Live.
    [ Edited by Jim 03.07.2015 - 19:36 ]
  • »03.07.15 - 20:12
    metatron
    Today I got my sam460cr.
    Morphos 3.9 doesnt seem to support PCIe-2-PCI Bridges. I tried one with an emu10k1 (SB-Live!) soundcard, but the soundcard wasnt recognized.
  • »03.07.15 - 20:18
    > And he moved on.
    So he created a port for the platform(s) he moved to from the original Amiga version :-)
  • »04.07.15 - 05:06
    > And he moved on.
    And continued to enhance the other ports, while not upgrading the Amiga version.
  • »04.07.15 - 14:32
