Posts: 265 from 2006/8/31
Cool_amigaN wrote:
Hey, I would like to have CDDA support (mostly for old CD games :)) on a G5 PMAC that has installed a SB Live over PCI-X.
Should I change the drive with an old IDE one, then use a a convertor from IDE to SATA while the audio cable will be installed directly from the drive to the sound card? Will that work?
Why that ?
If you wish to hear a audio cd, insert such cd in a cddrive and look, whats happend :)
MorphOS support audiocd and show you the table of contents. You can easy play every track
like every other soundfile.
Old game cd's include one or more cdda tracks, so they are appear as second cd in Ambient.
[ Edited by pegasos-sigi2 17.06.2015 - 09:55 ]Spreedy - The spreedsheet editor of MorphOS
