MorphOS Developer
Posts: 1090 from 2004/9/23
Quote:TheMagicM wrote:
Figured it out..
I had MorphOS set to get an IP via DHCP. I set it all statically and it worked. I guess something in MorphOS isnt saving maybe the default route or something?
Anyway..works
I guess your NAS got a different ip from your Router on PowerUp.
Also do not use the IP, but the name of the NAS as host.
e.g.
... service=//myHomeNAS/Music ...
Every NAS provides a name setting option. This avoids any IP trouble e.g. when you take your NAS into a different environment the same service string will work without any change, even if the ip is completly different.
[ Edited by geit 16.05.2015 - 15:34 ]
