MorphOS 3.7 iBook external monitor questions
    robdun
    Posts: 8 from 2011/5/9
    Hello, I would like to use my iBook with a external monitor. I have a 1.2Ghz iBook running MorphOS 3.7. I know there is a hack that allows an iBook to connect to a exernal monitor with out mirroring the display, but is it possible to connect a monitor and have morph OS recognize it? The cable I'd be connecting is a mini vga to vga.
    Thanks,
    robdun.
    Edit: What I want to do is connect my iBook to a external monitor and use the monitor intead. I don't want a multi-monitor set up. I only want to use the external monitor and have my iBook closed.
    [ Edited by robdun 19.02.2015 - 17:25 ]
  • »19.02.15 - 22:43
    Posts: 607 from 2003/4/11
    There is no direct option in MorphOS 3.7 actually. Some people have tried to add more modes to the standard mode file and made it work to some degree.
  • »21.02.15 - 09:28
    bash64
    Posts: 974 from 2010/10/28
    I just plug in my 27" monitor and It syncs reasonably to my 1440x900 powerbook screen. I loose maybe 50 scanlines off the bottom but no big deal.
    However, there is no direct support for the external port yet.
  • »21.02.15 - 14:15
    Norbi
    Posts: 99 from 2004/6/19
    MorphOS + iBook support external monitor, but only 640x480
  • »19.04.15 - 16:22
