Peg 1/ G4
    TheMagicM
    Posts: 1220 from 2003/6/17
    Is there a G4 module for the Peg I? If so, where does the cpu speed
    get set? is it on the add-on card? And if it is available, where can
    we get a G4 module/price?
  • »05.03.04 - 02:02
    poundsmack
    Posts: 1346 from 2003/6/7
    i don;t think it can be done.....but mabey i am wrong
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »05.03.04 - 02:40
    Chain-Q
    Posts: 350 from 2003/10/12
    Most Peg1 mainboards can't accept a G4 CPU. This is a known issue of the Artica chipset. The CPU speed is set on the CPU card itself. G4 modules were never officially sold for Peg1, at least not in high quantities, AFAIK. If you want a G4, better trade-in your Peg1 for a Peg2/G4. Pegasos2 CPU modules can't be used (neither G3 or G4) in Peg1 boards.
    [.Hosting AmigaSpirit.hu.]
  • »05.03.04 - 02:40
    Posts: 2732 from 2003/2/24
    Actually, the Pegasos1 G4 was officially sold, but only in a
    combination of motherboard and CPU module, because they had to
    manually test which CPU's that worked with which motherboards. I
    remember BBRV said that quite few was sold, only about 25 or so.
    Here you can get "in contact" with one of them (as a server):
    http://www.pegasos.org
  • »05.03.04 - 07:34
