sil sata adapter pci
    sabbate
    Posts: 110 from 2013/7/7
    hi all
    I wanted to update my powermac which adapter should I buy?
    thanks
  • »02.03.15 - 10:27
    Whatever happened to the driver that was created for other controllers?
  • »02.03.15 - 12:28
    sabbate
    I checked the website morphos in the compatibility list and is mentioned controller sil
  • »02.03.15 - 13:32
    Yes, from what I understand 2 channel Silicon Image 3x1x controllers are supported natively in MorphOS now.
    But I thought someone else had recently mentioned a second controller series with drivers.
  • »02.03.15 - 13:38
    Posts: 2577 from 2003/2/24
    Sil3112 based cards are <10€ on eBay and should work out of the box.
    You might even be able to reflash them to PPC/OF allowing use in OSX and cold boot from SATA.
    [ Edited by Kronos 02.03.2015 - 16:42 ]
  • »02.03.15 - 13:41
    Before I moved solely to G5s and PowerMacs, I used a combo of an IDE boot drive and an SATA drive controlled by an Sil based card to get by the firmware issues (obviously under MorphOS exclusively).
    Now let's see, who's idea was that...
  • »02.03.15 - 14:05
    Posts: 12557 from 2003/5/22
    It's still there:
    http://www.219.dic.at/?pid=detail&cat=software&type=projects&id=e9fab237
    https://morph.zone/modules/news/article_storyid_2076.html
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9662&forum=9&start=9
  • »02.03.15 - 15:08
    It's still there:
    http://www.219.dic.at/?pid=detail&cat=projects&type=native&id=e9fab237
    Very nice!
    Thanks Andreas, I've been thinking about that one lately.
    Promise controllers...wonder if there is a speed difference?
  • »02.03.15 - 15:11
