Which SSD + IDE Adaptor for PowerBook G4?
    Cego
    Posts: 738 from 2006/5/27
    Hi there!
    I was thinking about changing my current SSD, which is pretty dated and slow, with a new SSD. As we know there is no TRIM Support in MorphOS, so the drive should have something like that in it's hardware. Garbage Collection or Hardware TRIM or something like that.
    I read that it's possible to use 1,8" SATA drives with an SATA-IDE adaptor in the PowerBook. Which adaptor should i take? Do i have to consider some specific features?
    Which drive+adaptor combination do you suggest? I was thinking about a 128GB drive.
  • »01.03.15 - 11:10
    Posts: 2539 from 2003/2/24
    mSATA is the keyword you should search.
  • »01.03.15 - 15:19
    Lord76
    Posts: 81 from 2014/8/31
    @Cego
    Nimm am besten eine Samsung Evo mit mSata Anschluss und ein Adapter dazu.
    Hatte erst eine Mach Xtreme SSD im G5 stecken, damit wollte er nicht hochfahren. Bin dann auf Samsung gewechselt, die geht auf Anhieb und bietet Dir das gewünschte.
    Powerbook G4 A1138/39
    Powermac G5 2.7ghz / G5 11.2 2.3ghz
    Amiga1200 V1200/Pistorm
  • »01.03.15 - 21:28
    DanicaTalos
    Posts: 451 from 2010/10/15
    A IDE SSD with 128GB cost on eBay (Art.Nr. 171521465113 ) 95,-
    A mSATA SSD (Samsung Evo) with 128GB + IDE Adapter cost on eBay ca. 94,-
    iBook G4 - 14" -1,42 GHz - 32MB VRAM - 1,5GB RAM - 60GB mSata - MorphOS 3.19
  • »02.03.15 - 08:30
    Cego
    i think mSATA+adaptor is the better choice. i could easily change the ssd with a newer one and it would be less expensive.
  • »02.03.15 - 09:37
