PowerBook G4 LCD backlight.
  • ede
    ede
    Posts: 35 from 2011/4/18
    Hi.
    Is there any possiblity to change backlight intensity ? (ADB keyboard and touchpad)
    Ps. Especially brighten :{
  • »26.02.15 - 10:17
    bash64
    Posts: 974 from 2010/10/28
    I think that is in your Preferences.
    On a Powerbook G4 I think it is called LAPTOP.
    My G4 is broken right now so I cannot go look.
  • »26.02.15 - 10:35
  • ede
    ede
    I never had this in the preferences. Only one - use the fn key or not, but on my PB function keys do nothing.
  • »27.02.15 - 08:35
  • ede
    ede
    I copied laptopquick.conf file from another PB and changed 'Backlight ' value but no effect.
    It seems that some models have not been tested.
  • »27.02.15 - 09:33
